In most cases, the chain will last the life of the engine. But this does have a lot of miles on it. Does it sound any different now when you crank it to start? For example, does the engine sound like it's spinning faster? If possible, record it cranking so I can hear it. In most cases, I can tell if it jumped timing.
The code you had was related to the knock sensor. The sensor, based on engine vibration, fine tunes ignition timing. Since you said it got louder, it may have something to do with this. However, if timing has jumped, the sensor wouldn't be able to compensate for that issue.
What I suggest is this: First, record the engine cranking for me to hear. Next, check to see if the engine is still getting spark and fuel. Here is a link that will help you with a crank no start condition. It will cover both things I mentioned.
Once I hear it, I may recommend doing a compression check which will tell us if timing is an issue. Here is a link that shows how that is done:
Now if the engine is a single overhead cam engine (SOHC) we are safe. If it is a dual overhead cam (DOHC) and the timing has jumped, that is a concern. The DOHC engine is an interference engine which may indicate that internal damage was done.
We'll take it one step at a time. Let me know what you find with the things I suggested and possibly upload the engine cranking for me to hear.
Oct 18, 2020 at 6:28 PM
