Okay, then these are two different problems, it sounds like the fuel pump is weak and needs replacement but o be sure this guide will show you how to check it.
Fuel pressure
ITEMS .................... STANDARD VALUE
Vacuum hose disconnected .................... 330 - 350 kPa (47 - 50 psi) at curb idle
Vacuum hose connected .................... Approximately 270 kPa (38 psi) at curb idle
You can rent a fuel pressure gauge for cheap at the auto part store. Here is how to change the pump out in case it fails, please start a new thread for the coolant leak issue. Fortunately you have a trap door so the fuel tank does not need to be removed. Check out the images (below). Please let us know what happens.
Sep 17, 2024 at 3:23 PM
