Sometimes after driving in traffic the car will shift down hard and when you try to drive at higher speeds the car will not shift into overdrive. I will pull over , turn the engine off and right back on and the car will run fine. It will shift right in to overdrive like its suppose to. It shift smooth and runs fine.its like it resets itself after you turn the engine off and then back on.
Aug 22, 2013 at 8:45 AM
