Car shuts off while driving, or won't start. Just hear clicking sounds.
1975 CHEVROLET LUMINA
10,500 MILES • V6 • AUTOMATIC
KAYPORTER
I'm told by my repair shop, something is draining my battery. New battery, alternator and starter is good. Had towed for the second time and they said the bulb to the overhead dome light was burned out but the switch was left in the on position which was the cause of the battery drain.
Was okay for a few days, then started turning off on it's own again and unable to start again. Help!!
Oct 12, 2015 at 12:32 PM
HMAC300
  • 48,601 POSTS
because you have a few things on your car that modern ones don't check this in the dark. Trunk, Hood, and glove box lights are big offenders of this. so look from outside the car at glove box and hood, trunk light just disconnect and see if stops. One other thing is to remove positive cable , hook a test light between battery and cable. then pull fuses one at a time when light goes out you have found the offending circuit. If anything has been added to car lately disconnect that as it may be the one doing it. this is listed under How to Repair-electrical-item9 on our site here. a volt meter will work as well but a test light is easier to see.
Oct 12, 2015 at 3:55 PM
