Car shuts off doesn't start until car is cold
1985 BMW 325
165,000 MILES • 2.7L • 6 CYL • RWD • MANUAL
DAVIDTHEBMXER
  • 19 POSTS
The car will turn off when the engine gets warm and won't even try to start until the engine gets completely cold. A least an hour later. I am not getting spark. I have xonfirmed that there is voltage to the ignition coil , replaced the coil, replaced cap and rotor, conformed it is getting gas. I do not know what else could cause this. When the engine gets cold it fires right up
Dec 9, 2015 at 4:02 PM
DAVIDTHEBMXER
  • 19 POSTS
Also I have changed the crank sensor
Dec 9, 2015 at 4:04 PM
Most likely the cause is a bad crankshaft sensor.
Dec 9, 2015 at 4:34 PM
DAVIDTHEBMXER
  • 19 POSTS
I already changed that
Dec 9, 2015 at 5:35 PM
Was it properly set? Are you getting power to the crank sensor? It could be a problem with the computer itself.
Dec 10, 2015 at 6:35 PM
