I checked both of the connections the both looked good and seemed to connect smoothly. started the car and pressed on the accelerator and the engine idled up about 200 RPM. The engine light came on so I checked the codes a retrieved codes p2104 and p2112. The same codes as the last time.
Thank You
Don
Jul 27, 2017 at 2:23 PM
CERTIFIED EXPERT
It sounds like the throttle actuator or throttle position sensor is bad and needs to be replaced. That's where I would head next.
