security light stays solid/always on?
2001 CHEVROLET TAHOE
255,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
JUWANSAYLES
  • 16 POSTS
I replaced the fuse and got a new Anti-Theft Vats Security Module but still SUV starts and immediately shuts off, and no response when I press the lock or unlock button on key fob.
Aug 5, 2025 at 10:30 PM
Is the security light flashing? If it is flashing the system is enabled. I would try a hard system reboot. Also, do you have another fob? It could be the batteries inside the fob are dead. We can run the codes with a CAN scanner to see if the security system is working or what codes are involved. This video will show you how:
https://youtu.be/u-4syLc-ifQ
Here is the guide to show you how to do the hard system reboot, this will clear the system out.
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Please upload pictures or videos in your response.
Aug 6, 2025 at 11:38 AM
JUWANSAYLES
  • 16 POSTS
Changed battery in keyfob, no change, did every system reboot in the giving instructions, and still no change
Only codes im gettin is for some 02 sensor and camshaft sensor, I been gettin them codes.
But my security never was flashing, it's solid, as in always on never off until I disconnect the battery
Aug 13, 2025 at 6:22 PM
If the security light is on solid that means it means the system is in stand by so that may not the problem. To be sure we should do a CAN scan which is not a regular scan, please go over this video so you can see.
Can I ask if the engine cranks over, also there are three fuses that run the security system did you check them all? TBC fuse under the hood, IGN1 and CRUISE fuses in the fuse panel inside.
Aug 14, 2025 at 8:09 AM
JUWANSAYLES
  • 16 POSTS
All fuses are good, it does crank and start but immediately dies, working on getting CAN scanner now
Could the BCM have gone out or fried?
Aug 15, 2025 at 6:56 AM
O ya, this does happen, the CAN scan should pinpoint the issue. you can get a preprogrammed BCM from Flashmasters for like $200.00.
Aug 15, 2025 at 12:17 PM
JUWANSAYLES
  • 16 POSTS
Bought a CAN scanner but due to me unhooking battery and the truck starting but immediately stalling after starting, I have no codes or lights on the dash at all but the security light, I did by one used BCM from ebay to see if something would happen. I notice that the one I pulled out my truck, had a couple burned spots on it, idk if they should be there or overtime it happen
Aug 17, 2025 at 7:05 PM
A used BCM will need to be programmed to the truck, this is why I suggested Flashmasters. Also, I cannot see the burn marks on the board but any burn marks are not good. I think you found the problem.
Aug 18, 2025 at 10:46 AM
