Car screeching when I crank it?
2014 BMW 320I
97,700 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
YELLADUDE901
  • 6 POSTS
Car screeching when I crank it. It stops when I rev it 2 or 3 times. It only does it whenever I crank the car. After Revving it stops. It also stalls when it's screeching.
Jun 28, 2023 at 4:58 PM
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on.. You can upload it here with your response.
Jun 28, 2023 at 5:43 PM
YELLADUDE901
  • 6 POSTS
It sounds like it's coming from where the phone is. When I rev it 3 times it goes away. It only does it when I crank the car and let it run.
Jun 29, 2023 at 6:45 AM
Thanks for the video, it helps, it sounds like a vacuum leak or the PCV system has a leak, I would use this guide when the engine is cold only to see if you get a reaction from the spray, this will tell you where the problem is.
Here are some areas to check. Check out the images (below). Please let us know what happens. If you can find a leak, please remove the serpentine belt and start the engine for a few seconds to see if the noise is gone. Let me know what you find.
Jun 30, 2023 at 9:47 AM
YELLADUDE901
  • 6 POSTS
How do I find the oil return line?
Jul 1, 2023 at 12:36 PM
YELLADUDE901
  • 6 POSTS
I changed the tensioner, belt and PCV hose, but it stills make a whine. It's like from the middle of the engine.
Jul 1, 2023 at 12:41 PM
YELLADUDE901
  • 6 POSTS
I finally found the noise. It's coming from under the car in the middle.
Jul 1, 2023 at 1:58 PM
YELLADUDE901
  • 6 POSTS
It's also dripping a lot of water. I believe they coming from the turbos. Because it's dripping from both sides underneath a lot.
Jul 1, 2023 at 3:05 PM
Is the noise coming from the turbos? I have seen them go bad and create a whining noise. If the turbos are bad here is how to change them out. Check out the images (below). Please let us know how it goes.
Jul 3, 2023 at 12:19 PM
