car runs bad
2005 CHEVROLET IMPALA
121,000 MILES • 3.4L • 6 CYL • AWD • AUTOMATIC
BEVERLY MAYNARD
  • 31 POSTS
i did what you said I check all fuse vacuum lines I got it down to the MAF sensor I unplug it and it ran like was before this started. will it hurt my engine if I keep it unplugged? thank you so much for your help.
Aug 23, 2017 at 2:44 PM
Yes is not good to run it will it disconnected, did you try replacing the MAF sensor?
Here is a guide to help:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Please let us know what you find.
Aug 24, 2017 at 11:26 AM
BEVERLY MAYNARD
  • 31 POSTS
i put a new one on last month it seemed to run worst than it did, but it starts on a third try now. the sensor to the left of it shows to not have power but when i unplug it i get a click in back of the motor, the same as putting it back on. I know it is something simple I just cannot find it. thank you, BENJAMIN
Aug 24, 2017 at 1:53 PM
It sounds like you have a bad ground wire, can you go over the wiring harnesses to check that the grounds are clean and tight?
Aug 25, 2017 at 12:19 PM
BEVERLY MAYNARD
  • 31 POSTS
the only ground wire I know of is on the starter and I cleaned it any others I don't know about there are so many to count can you tell me of any others ??? thank you benjamin
Aug 25, 2017 at 5:55 PM
Can you check the main battery cables for corrosion or bulging?
Aug 25, 2017 at 7:12 PM
BEVERLY MAYNARD
  • 31 POSTS
the battery is new I cleaned the post can you tell me if there is another ground of some kind I'm missing ?? thank you BENJAMIN
Aug 26, 2017 at 12:24 PM
Ya it sounds like it.
Aug 28, 2017 at 4:22 PM
