I have a 199.5 vw jetta vr6 AFP!I am getting many electrical short to ground codes and i cleaned the terminals under the battery box and the car is still running really rough and really rich! I noticed that on the alternator there is a visible nut that is on a screw and there is no BIG wire attached to it! The kid i bought the car from just had the alternator replaced. Coilpack and plugs replaced.The camshaft sensor also had oil in the plug and was bad and i replaced it and still runs rough and when i down shift it pops like a lil bit of backfiring going on! My MIL and ABS and a the other lights in the middle cluster will not illuminate and my temp gauge is also not moving.I am going to check the converter to see if it is clogged but i want to figure out the electrical short faults that i am getting! Here is the scan! I also replaced the 409 relay and nothing changed! I replaced #3 fuel injector it was cracked and it ran a lil better but it runs like crap still and shakes some! I do have a spare ECM but i dont want to put it in if that is not the issue! Someone told me to check the ignition switch but i dont know if that would cause this issue! Any help would be great! :)
20 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
16497 - Intake Air Temp. Sensor (G42)
P0113 - 35-10 - Signal too High - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
17834 - EVAP Purge Valve (N80)
P1426 - 35-00 - Open Circuit
17950 - Angle Sensor 1 for Throttle Actuator (G187)
P1542 - 35-10 - Implausible Signal - Intermittent
17952 - Angle Sensor 1 for Throttle Actuator (G187)
P1544 - 35-10 - Signal too Large - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-10 - - Intermittent
17633 - Fuel Injector for Cylinder 1 (N30)
P1225 - 35-10 - Short to Ground - Intermittent
17637 - Fuel Injector for Cylinder 5 (N83)
P1229 - 35-10 - Short to Ground - Intermittent
17635 - Fuel Injector for Cylinder 3 (N32)
P1227 - 35-10 - Short to Ground - Intermittent
17638 - Fuel Injector for Cylinder 6 (N84)
P1230 - 35-10 - Short to Ground - Intermittent
17880 - EVAP Leak Detection Pump
P1472 - 35-10 - Short to Ground - Intermittent
17843 - Secondary Air Pump Relay (J299)
P1435 - 35-10 - Short to Ground - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 35-10 - Short to Ground - Intermittent
17636 - Fuel Injector for Cylinder 4 (N33)
P1228 - 35-10 - Short to Ground - Intermittent
17923 - Intake Manifold Valve (N156)
P1515 - 35-10 - Short to Ground - Intermittent
17634 - Fuel Injector for Cylinder 2 (N31)
P1226 - 35-10 - Short to Ground - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
P1117 - 35-10 - Short to Ground - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 03604
Shop #: WSC 00066
VCID: 3663DDFA12827BAE71B-4B1A
3 Faults Found:
01276 - ABS Hydraulic Pump (V64)
16-00 - Signal Outside Specifications
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
35-00 - -
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
35-00 - -
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: C AIRBAG VW3 SG 0002
Coding: 00067
Shop #: WSC 00066
VCID: ECD7BF929C4E717ED7F-4B1A
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
Part No: 1J0 919 951 B
Component: A4-KOMBIINSTR. VDO V57
Coding: 06262
Shop #: WSC 00000
VCID: 2F6DE89EEDD84A6632D-5142
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
29-10 - Short to Ground - Intermittent
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 8603ED3AA2E2AB2E21B-4AE8
Subsystem 1 - Part No: 1J1959801C
Component: 61 T?rsteuerger. FS0001r
Subsystem 2 - Part No: 1J1959802D
Component: 61 T?rsteuerger. BF0001r
Subsystem 3 - Part No: 1J4959811C
Component: 61 T?rsteuerger. HL0001r
Subsystem 4 - Part No: 1J4959812C
Component: 61 T?rsteuerger. HR0001H
4 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01358 - Internal Central Locking Switch; Driver Side (E150)
27-10 - Implausible Signal - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
20 Faults Found:
16687 - Cylinder 3
Coding: 03604
Shop #: WSC 00066
3 Faults Found:
35-00 - -
35-00 - -
Coding: 00067
Shop #: WSC 00066
1 Fault Found:
Coding: 06262
Shop #: WSC 00000
1 Fault Found:
Coding: 04096
Shop #: WSC 00066
4 Faults Found:
Oct 11, 2014 at 6:37 AM
