Was this issue happening before you made this repair or did this just start after you did this?
It sounds like you have air in the system. When you have an air pocket it normally doesn't overheat until you start driving.
However, if this has been doing this from the beginning and the repair made no change then we need to check what the temperature is of the upper and lower hose when the vehicle is starting to overheat. Clearly you need to stop and check it when the temperature starts to rise and not when the coolant and steam are coming out.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Use a laser thermometer to do this as it is quick and accurate.
https://www.2carpros.com/articles/how-to-use-an-infrared-temperature-meter
Let us know what you find and we can go from there. Thanks
Jun 24, 2020 at 6:26 PM
