Car running hot
1995 NISSAN MAXIMA
199,999 MILES • 2WD • AUTOMATIC
LOVINGMY2
My car has started running hot, but I do not see anything leaking far as I can see. It is running hot and it shut off on me. So I let it cool and it cranked right up. What could it be?
Jun 28, 2018 at 9:56 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Just a few questions. When have you replaced (or ever replaced) the thermostat? Have you noticed if the electric cooling fan(s) are operating?
Jun 28, 2018 at 10:17 PM
LOVINGMY2
The person I got the car from said everything is new except the water pump. I did try and see if the fans were blowing but it was night so I really could not see. I took it to a mechanic he said some leaking behind the engine block by the timing chain.
Jul 1, 2018 at 8:29 AM
DANNY L
  • 5,648 POSTS
Hi there, Danny here.
It could be possible the water pump can be leaking and possibly have poor circulation. Water pumps have a drain hole built into them that will start leaking when the internal seal is worn. Have you noticed any coolant leaking where vehicle is parked? I have attached a tutorial showing a cooling system pressure test and a cooling tan tutorial. I would suggest having this done to see if it has any leaks. Most auto parts stores(Autozone, O'Reilly's, Pep Boys) have a tool loaner program for a cooling system pressure tester. Also, be sure to maintain proper Coolant level. Also, If you can have fans checked to see if properly operating.
https://www.2carpros.com/articles/radiator-pressure-test
Jul 1, 2018 at 11:45 PM
