My car typically idles at about 1,000. Car RPM's jump from roughly 500-1500 then drop down to 0. It started jolting but earlier today was fine. I was not driving my car (I had a few beers) but my brother was who has driven many manuals before. I don't think he wore my clutch out or anything crazy, he seemed to be driving it just fine. When we made it back home I toyed with it. I turned it on and let it idle in neutral.the check engine kept flashing and the tachometer would bounce for about thirty seconds then go to 0 the temperature gauge quit too, but the has and mileage was still there. When I would press the gas the rpm gauge was not registering. Turned it off and back on. Would register for a few seconds when surging (if that's the right term) and wouldn't register after 30 seconds. It has done something similar a few months ago where the car would completely shut off and would have to be turned off and back on. I took it to a shop and they replaced the ignition coil pack. I'm a girl so bear with me. I know a bit but not enough. I have replaced the spark plugs a few months back. There were used parts from a junk yard (he picked the nicest looking ones being a mechanic) put in as well by my ex which included a starter, alternator, new A/C belt, cleaned fuel injector, new map sensor, and many more I may not even be thinking of. Do you think it could be a head gasket? Maybe check the spark plugs again? Vacuum leak? Could it be a faulty sensor or fuse? I'm somewhat knowledgeable from being with someone who worked on cars and helped pull parts, but I'm not very good with diagnosing. Please help :(
Apr 13, 2020 at 5:46 PM
