car revs high but does not pull power till 6000 rpm
1988 TOYOTA SUPRA
195,000 MILES • 3.0L • 6 CYL • RWD • MANUAL
88SUPRA
The was ruining great I changed the spark plug wires then I noticed the clutch slave cylinder was broke so I changed it then when I went to test drive it the car would run change gear and everything. The only problem was that after second gear the car would Rev but would not pull till 6000 rpms n would do the same second third fourth and fifth gear
Feb 22, 2015 at 12:33 PM
HMAC300
  • 48,601 POSTS
check for clutch adjustment if any and check for air in slave system
Feb 22, 2015 at 1:57 PM
