I'm not familiar with that change. Do you know if it is a direct fit? For example, does it secure the same in the dash, do all wiring connectors plugin, or do you need to make any other modifications?
I did read through the link you included, and it appears to be a good choice. However, towards the bottom, there is a small section listed as remarks. That is the only thing that makes me question it. When they start the remarks with a sentence fragment, "factory functions which are mentioned above as an example." It concerns me. I don't even know what that means. After that it indicates certain things won't work on different vehicles.
Take a look and let me know your thoughts.
Jan 22, 2023 at 4:57 PM
