This sounds like a crankshaft angle sensor is going out, but to be sure when the engine stalls we need to check for spark. here is a guide:
If there is no spark I would replace the sensor here is a guide to show you what you are in for when doing the job. When the crankshaft sensor goes out most of the time it will not set a code.
The crankshaft sensor is located at the rear of the engine lower left near the transmission flange.
Feb 5, 2018 at 9:39 AM
