Transmission problems
2005 CHEVROLET MALIBU
220,000 MILES • AUTOMATIC
JAZYOUNG28
  • 6 POSTS
One day I was driving and it would not go forward. I am hearing G might need new transmission. I cannot afford that right now, but I would like to know what is going on. Last year I had to buy a used part from lkq it was a sensor part for the shifts. Something popped out the car keeps going dead since it has been sitting. Lights everything will come on when it get a jump.
Nov 18, 2018 at 7:14 AM
JAZYOUNG28
  • 6 POSTS
When it would not go for me I had someone to push me to my mamma's and I parked it put transmission fluid in it and have not tried to start it since then.
Nov 18, 2018 at 7:27 AM
Good morning.
Start the engine and check the fluid level. If it is low on fluid, it will not move.
Beyond that it is most likely an internal issue.
https://www.2carpros.com/articles/automatic-transmission-problems
Nov 18, 2018 at 8:03 AM
JAZYOUNG28
  • 6 POSTS
Okay, so I started it up it took off got around the corner and it will not go forward anymore.
Nov 18, 2018 at 2:29 PM
Did you check the fluid level before you drove it to be sure it is the correct level?
When was the last time you change the oil/filter in the transmission?
Nov 18, 2018 at 2:53 PM
JAZYOUNG28
  • 6 POSTS
I got an oil change February put transmission fluid in it after it stopped the first time.
Nov 19, 2018 at 6:48 PM
Did you have the transmission fluid changed or the engine oil?
Nov 20, 2018 at 1:41 AM
JAZYOUNG28
  • 6 POSTS
No.
Nov 22, 2018 at 7:42 AM
Again, did you have the transmission fluid changed?
Nov 22, 2018 at 11:44 AM
JAZYOUNG28
  • 6 POSTS
No, I did not have the transmission fluid changed. Doing that today. What all do I need and it is that all I need to do.
Nov 22, 2018 at 12:51 PM
You will need a filter and pan gasket and about six quarts of fluid.
The parts house will get you the parts you need.
Nov 22, 2018 at 1:12 PM
