Hello Steve W.
1. I checked with my local Nissan CO. website and I didn't find anything related to the Owner's manual.
2. Are you really sure that my Transmission is a CVT?
If so, what does CVT refer to and its specs?
isn't with only 4 gears as some of them said?
Every motor company sells you anything from their mind. coz every time I go to them, they said take this or that, where the Owner's manual is different from what they gave.
Time ago, I replaced/changed my Gear oil fluid from the Nissan CO as they suggested for me + I have no manual as I already told you, so I bought the Gear oil Fluid with its Filter and sealing rubber, after some time I got some kind of stuck on some gears where the gears can hardly shift from gear to another and RPM start to freeze at high RPMs. so, when the gear is hardly changed to another, the RPMs will go higher 4-5 round per minute in this case.
Afterwards, I did a computer check, because no one can figure out what the issue is.
The computer check result comes out that there's an issue in 2nd / 3rd gear + the A/T Vehicle speed sensor faulty code.
Is that because of Oil?
So, I went out to change and replace the "Vehicle speed sensor" from scrap parts and fixed it back, now it looks better than before when the RPMs fluctuated. This done I guess two months ago.
Thanks.
Jan 23, 2022 at 10:09 PM
