Car overheating and white smoke coming from the rear end
2000 MERCEDES BENZ S500
137,344 MILES • 0.5L • V8
DRE409
My car has been overheating. When I start my car white smoke comes from the rear ends at once, I start driving the engine heats up to around 76c after a little less than 5 minutes. Then once I've been driving for about a mile or so it hits 80c and fluctuates from 80 to 90c. Then once I make it to my destination it climbs up a little more. I've replaced the radiator fan, temperature sensor and head gaskets, still no luck.
Jul 6, 2022 at 7:50 PM
White smoke or steam from the exhaust system says there is coolant being consumed by the engine, when you replaced the head gaskets did you have the cylinder heads pressure tested? If so and they are okay, you have a cracked engine block, and the engine is no good. These guides can help you understand what's going on:
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
and
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Jul 7, 2022 at 12:08 PM
DRE409
It maybe steam because it's never a lot! My car doesn't leak oil or coolant though so if and I don't have any lights on except my ABS and SRS.
Jul 7, 2022 at 1:25 PM
Okay, the engine overheats, correct? We should do a chemical check the cooling system; it does take much coolant loss to have the engine overheat. Here is a guide to help with the test:
Jul 9, 2022 at 9:40 AM
