Car overheating
2002 CHRYSLER 300M
178,000 MILES • 3.5L • 2WD • AUTOMATIC
ALY CASPER FOSTER
My car suddenly started overheating, the heat in the car at the same time started not working correctly taking longer to turn on and when slowing down or stopping will turn cold. My fans are not turning on as they should either. The motor has been checked and the water pump too, they are fine. Have checked for leaks but have not found any. the car usually has to have water put in every other day sometimes not a lot sometimes up to a gallon no matter how far I have driven. As long as the heat runs and i am driving steadily the car stays at the 3/4 line where it has been since i got the car which the car company told me was normal. My father thinks it might be the ECM/PCM but i'm not sure and want a opinion before paying for that part.
Dec 22, 2018 at 11:06 AM
Good afternoon,
The fact you are using water with no leak concerns me.
I would start by having a leak down test done on each cylinder to be sure there is not a head gasket leaking.
Are the cooling fans working?
Dec 22, 2018 at 11:19 AM
