If it is making a bad noise, chances it isn't a shift solenoid or the TCM. Has anyone checked the fluid level or condition? Is it possible for you to upload an audio of the noise so I can hear it?
If there are no broken CV joints or axles and the noise seems to be coming from the transmission, it really sounds like an internal hard part issue or it could even be a broken flex-plate. The inspection plate on the transmission should be removed and the flex plate checked as well as making sure the torque converter is tight.
Take a look through this link:
https://www.2carpros.com/articles/automatic-transmission-problems
Let me know if anything in the link seems to mirror what you experience and if there is anything helpful.
Mar 15, 2019 at 9:28 PM
