Car not starting
2009 NISSAN 240Z
12,500 MILES • 3.0L • 4 CYL • 4WD • AUTOMATIC
BRIANMAKOSA
I have Isuzu como with a ZD30 COMMON RAIL which is not starting on OBD 2 Machine we are getting this fault code p0341 Camshart Position Sensor A Ciruit
Bank 1 or Single Sensor
Sep 15, 2019 at 5:53 PM
MASTERWRENCH
  • 258 POSTS
Welcome to 2CarPros!
P0341 is a generic OBD II code and basically means that the PCM is not receiving a valid signal from the camshaft position sensor. I would start by inspecting the wiring from the sensor back to the PCM connector. Pay close attention to areas where the harness makes hard turns around engine mounts or components. These are typically areas were wires will begin to rub through, causing a short to ground. If you don't find any wiring issues, there's a good chance the code is the result of a failed sensor.
Let us know what you find!
Sep 17, 2019 at 10:09 PM
