So when you first try to start it what does it do? Loud click, chatter or nothing? If you turn the headlights on, do they come on? What do they do when you turn the key? I'm just trying to figure out if the battery is very low as a result of a parasitic draw (interior light staying on or module not shutting down)and requires a jump for that reason OR is it something like a high resistance in a starter relay or starter motor that the higher current of the second battery helps overcome.
Jan 18, 2017 at 2:36 AM
