It could be several different things. First, if the check engine light stays on when the engine is running, you should first scan the computer for diagnostic trouble codes. Here is a quick video of how it's done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but if the car is safe to drive, most parts stores will do it for free.
______________________________________
Next, I would suggest checking the fuel pump pressure to confirm it isn't weak. Here is a link that shows in general how it is done:
Here are the manufacturer's specs for pressure:
Key On Engine Off 35 - 45 psi
Key On Engine Running 30 - 40 psi
Another thing that can cause a misfire or sputtering is an engine vacuum leak. Here is a link that shows how that is done:
Start with checking those things, However, if the check engine light is on, scan it for codes. That can point you in the right directions. If you find any, let me know what they are and I can better direct you.
Jan 10, 2019 at 6:41 PM
