Car not running smooth
2015 DODGE CHARGER
37,000 MILES • 5.7L • V8 • RWD • AUTOMATIC
CRISTIAN TORRES
I do not feel the car running smoothly. Every time I press the gas it feels like everything is moving. A while back I got on top of a sidewalk on the driver side only, after that the problems started happening. I took it to discount tire where I recently purchased new set of tires thinking that the tires might be damage but they said everything was fine but the tires where badly aligned, it still felt the same when I left. I was thinking it might be the suspension because every time I go in a speed bump the whole car moves but It seems that the problem is coming from the driver side. That is where it usually starts moving first. I do not know what could be the problem.
May 14, 2017 at 5:23 PM
STEVE W.
  • 15,113 POSTS
Take it to the dealer and tell them it does not handle correctly. That car should still be under warranty. They could at least tell you if there is an actual problem.
May 14, 2017 at 5:49 PM
CRISTIAN TORRES
I already have an appointment on Tuesday I will tell them that thanks.
May 14, 2017 at 8:31 PM
May 17, 2017 at 3:30 PM
