Car not going forward or backwards
2002 MERCEDES BENZ 200E
150,000 MILES • 2.0L • 6 CYL • TURBO • 2WD
SAMUEL PHIRI
The car has an automatic transmission goes into drive but cannot move forward or backward. starting without problems. what can a problem be?
Jan 7, 2018 at 5:35 AM
When you move the gear selector do the indicator lights move as well? Also, the first step would be to scan for codes here is how:
Please run this test and get back to us.
Jan 7, 2018 at 8:31 PM
SAMUEL PHIRI
Thank you Ken. I will do as you suggested, but I do not have a code reader. i just also found out the driveshaft is not rotating when I started the car. can this be caused by a sensor?
Jan 7, 2018 at 9:59 PM
It could be. that is why we need the codes read to tell us which sensor it is. They have scanners for cheap ($17.00 US) on Amazon.
https://www.amazon.com/Veepeak-Automotive-Diagnostic-Compliant-Vehicles/dp/B01I8UJ0V8/ref=sr_1_5?s=automotive&ie=UTF8&qid=1515441191&sr=1-5&keywords=engine+code+scanner
Jan 8, 2018 at 11:53 AM
