This model wasn't offered in the US until 2014, so my technical information is very limited. I can tell you that what you described sounds like a loose belt. When the vehicle is first started, that is when the most load is placed on the alternator. If the belt is loose or worn, it will squeal.
With the engine off, check to make sure it is tight. If it is, try this. Start the engine. While it is making the noise, pour a small amount of water on the belt. If it chances pitch, sound, or even stops, replace the belt and them make sure it is properly tightened.
I did attach a picture of the belt on a 2014. I circled the alternator. I don't know if yours will be the exact same.
If you try the water trick, the engine will be running, so protect your eyes and clothing. Water and dirt can fling off the belt.
Let me know what you find.
Feb 24, 2020 at 5:53 PM
