car makes whurring noise under hood when car is started up and running
2003 DODGE DURANGO
96,000 MILES • 4.7L • V8 • RWD • AUTOMATIC
BDE31940
Check engine light recently came on and whurring noise started happening. Noise happens when idling and running, sounds like the fan is pushing itself too hard or the engine is. Any suggestions?
Jan 19, 2015 at 5:59 PM
CARADIODOC
  • 34,306 POSTS
If you have a fan clutch, it could be binding causing it to run all the time. That will make excessive noise. You can identify that by trying to turn the blade by hand, (engine off hopefully!). Do you know how to read the diagnostic fault codes?
Jan 19, 2015 at 6:04 PM
