Engine makes a clicking noise when trying to crank?
2012 INFINITI G37
185,000 MILES • AUTOMATIC
KENDIBELL1
  • 14 POSTS
I tried to crank the car and made a clicking noise. I just replaced the battery and alternator, so I bought a starter they put it on today and said it's still making the clicking noise. What can it be?
Feb 25, 2023 at 6:30 PM
Does it seem that the clicking is coming from the starter motor? By any chance, did you try turning the engine by hand?
Also, if it is loud enough, record it and upload it for me to hear.
Feb 25, 2023 at 11:38 PM
KENDIBELL1
  • 14 POSTS
Yes, it sounds like the starter and no I don't know anything about turning a motor. I did purchase the starter used.
Feb 26, 2023 at 2:26 AM
No problem. If the starter is clicking, it usually indicates a weak battery. However, you indicated a new battery made no difference.
If the battery is new, the alternator, and the starter, my concern is the engine may have locked. The only way to check this is by turning the crankshaft to see if it moves.
If you look below, I attached the serpentine belt routing diagram. I highlighted the crankshaft pulley. There will be a bolt centered in that pulley. You need to place a socket on it and using a breaker bar, see if you are able to turn the engine by hand. It will be tight, but you should be able to turn it.
If you can, record the clicking and upload it for me to hear. It may help me determine what is happening.
Take care and let me know what you find.
See pic below.
Feb 26, 2023 at 7:55 PM
KENDIBELL1
  • 14 POSTS
Thank you. I passed this info along to my mechanic he said he is about to try that now he said it is a single click it's making.
Feb 28, 2023 at 8:41 AM
A single click is usually the result of a weak connection. However, if the engine won't turn, the same thing can happen.
Let me know what you find. I'm interested in knowing.
Feb 28, 2023 at 7:27 PM
KENDIBELL1
  • 14 POSTS
Hey, Good morning. he replaced the starter turned the engine and I got a new battery still won't crank. he can't figure it out I don't know what to do now.
Mar 8, 2023 at 5:25 AM
Has anyone had the chance to confirm the engine isn't locked?
PS: Hang in there. We'll get it figured out one way or another.
Mar 8, 2023 at 6:58 PM
KENDIBELL1
  • 14 POSTS
I'm going to record the click in the morning my uncle said he will be here in the a.m. also I'll send you the audio.
I truly appreciate you.
Mar 8, 2023 at 11:58 PM
That sounds like a plan. I will watch for your reply.
Mar 9, 2023 at 7:24 PM
KENDIBELL1
  • 14 POSTS
My uncle thinks it is something with the engine, he has a machine hooked up to it saying it's giving some error codes.
Mar 15, 2023 at 4:21 PM
If it is locked up, this will cause what you are experiencing. However, usually, there are indicators that the engine is failing. For example, you may have heard knocking or ticking from the engine.
On the other hand, if a head gasket fails, it can allow coolant to enter a cylinder. As a result, you have a hydrostatic lock.
Let me know what you find. Also, if you have some of the codes that were found, let me know what they are.
Mar 15, 2023 at 6:52 PM
KENDIBELL1
  • 14 POSTS
It was the wiring throwing codes so he hooked up his computer and cleared them out, cranked right up.
Mar 15, 2023 at 7:01 PM
Is it running properly? Was it a wiring issue that was causing the issue? If so, do you know which wires were the cause?
I'm just interested in knowing.
Thanks,
Mar 15, 2023 at 7:10 PM
KENDIBELL1
  • 14 POSTS
He said something about a module and ignition switch and something about a module can make the car battery drawn thinking it's still on when it should be asleep.
I can ask him more tomorrow.
Mar 15, 2023 at 8:54 PM
KENDIBELL1
  • 14 POSTS
It's running great no pause when it cranks.
I got in the freeway and drove about 15 miles and came back.
Mar 15, 2023 at 8:55 PM
That is great news. If you do have a chance to ask, I would like to know what he did. Not only am I interested, but it will likely help others in the future.
Let me know and thanks for the update.
Mar 15, 2023 at 9:13 PM
KENDIBELL1
  • 14 POSTS
I sure will.
I know it took him 3 hours he printed out the diagram to the wiring system then hooked up some type of computer and when by down each module he said and it was giving error codes that he had to clear.
Mar 15, 2023 at 9:36 PM
KENDIBELL1
  • 14 POSTS
These are the diagrams he printed out and followed he told me to get up to see if it cranked right up and it did seems like it has more of a kick to it now when it cranks.
Mar 16, 2023 at 6:15 AM
Thanks for the update. I suspect it was either related to a fusible link or one of the relays. I can't read what is highlighted in pic 1, so I can't be sure.
Regardless, I'm glad to know it's fixed.
Take care and feel free to come back in the future.
Mar 16, 2023 at 7:36 PM
