Car leaked antifreeze all over pavement
1991 PONTIAC SUNBIRD
183,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
TRACIJOHNSON
I left the car to warm up this morning...20 minutes or so. When I got out to leave there was anti-freeze all over the pavement. My husband thinks it could be the thermostat...he also told me that thermostat was in the radiator and all I had to do was swap them out. Well, I looked this up and it's just a TAD more complicated than that! So...should I try and get someone to replace my thermostat or put in radiator stop-leak?
Nov 18, 2014 at 8:38 AM
SATURNTECH9
  • 30,869 POSTS
I need a couple questions answered where did the coolant leak from? Also how hot did the temp go higher then normal? Also I don't recommend stop leak I have seen it plug up heater cores etc.You could just have a leak and nothing to do with the thermostat we need to do some digging before we make that decision.
Nov 18, 2014 at 8:44 AM
TRACIJOHNSON
At the bottom of the radiator (right below the cap) there was a pool of antifreeze. The temp did NOT go past the first mark. I drove the 20 miles to my job and it registered below the 1st mark. When I got into town...I had to stop at a stop light and it started going past the 1st mark for the first time.
Nov 18, 2014 at 8:56 AM
SATURNTECH9
  • 30,869 POSTS
So was it coming out of the cap or the radiator itself? Also you could just have a bad radiator cap allowing the coolant to leak out because the cap no longer holds the correct pressure.
Nov 18, 2014 at 6:16 PM
