Battery keeps going dead after driving the car for a day
2006 HONDA CIVIC
215,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
CIVICXSE
i use the car for the day and the next morning the car struggles to crank or it’s completely dead. already hooked up the voltmeter on the fuses and can’t find the cause on what’s causing the battery to die.
Mar 6, 2020 at 9:50 PM
Have you checked to see if the alternator is properly charging the battery? Also, has the battery been load tested? Are the battery terminals clean and tight?
Here are a few links to help with testing:
Mar 6, 2020 at 10:05 PM
CIVICXSE
alternator is fine and battery is brand new.
Mar 6, 2020 at 10:27 PM
Did you try checking if there is an electrical draw by placing a volt meter or multi meter at the battery? Take a look at this link and drop down to step 5.
Mar 6, 2020 at 11:07 PM
