Flushed and replaced transmission fluid. Changed all solenoids. Restarted ECU by disconnecting battery and tapping negative and positive together. Typically, will work for a day or two after that with overdrive starting in first gear but then goes back to jerking with overdrive starting in fourth gear. Trying the speed sensor next. Does this car need specific Transmission fluid? Used Maxlife Valvoline ATF.
The car listed above is a non-hybrid.
Apr 17, 2022 at 12:37 PM
