Hi, P0102 indicates low airflow through the MAF (Mass Airflow Sensor), let's start with the basics and check the engine air filter. This should be a large black box with a snorkel on it, and if it is very dirty it could cause some issues with acceleration. We should also look / listen for vacuum leaks or any kind of air leak in the intake system. This can usually be heard while the engine is running and typically sounds like air blowing or sucking into the tube. Next will be the MAF itself, see if it is damaged, or even dirty. The element could need a cleaning (only use MAF cleaner!).
Please let us know and report back,
William
Feb 21, 2025 at 7:27 PM
