Car jerks after changing gear
2004 VOLKSWAGEN GTI
129,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
STEPHENACHIEVIN
I recently purchased the car listed above and I’ve noticed the car jerks when I change gears (reverse and drive). not sure if this is a serious transmission problem or if the fluid is bad.
Aug 14, 2019 at 10:19 PM
STEVE W.
  • 15,113 POSTS
Hello and welcome to 2CarPros. By jerk do you mean it sort of lunges when put into gear but then shifts okay after that? Then jerks again when put into reverse? If so then I would start with a fluid change with an OEM fluid and filter. What is the engine RPM when it jerks? If it is running higher than 750-800 rpm it could make it harsh when it engages.
Aug 15, 2019 at 3:04 PM
STEPHENACHIEVIN
I’ll get back to you about the rpm. Currently on vacation and left the car bag home. But it really only jerks when I’m moving the gear from park to drive or reverse. Sometimes it will jerk when I’m reversing and switch to drive. I’m not sure if this has anything to do with it but my brakes are also kind of soft? I have to push the pedal far for it to fully engage. But yea, I’ll try the fluid change and everything when I get back.
Aug 16, 2019 at 11:42 AM
STEPHENACHIEVIN
Like when I’m really gentle and I shift from park to reverse and I ease of the brake pedal super slow it won’t jerk as bad or at all.
Aug 16, 2019 at 11:47 AM
STEVE W.
  • 15,113 POSTS
Okay, when you get back to it we can continue, hope it's a good vacation. The brakes shouldn't make a difference but the rpm's will. Soft brakes can be for many reasons, a sticking caliper, air in the lines.
Aug 16, 2019 at 4:06 PM
