Fluctuating idle and shutting off
2002 CADILLAC ESCALADE
190,000 MILES • V8 • 4WD • AUTOMATIC
VANDERBIE
The car will start to mumble and then it shuts off and i will get a jump and it will start up and then mumble and will drive a while then park it while at work and after work it wont start .so i will have to get it jumped to run again.
Aug 21, 2020 at 1:02 PM
Do you mean the battery is too weak to start it requiring a jump start? Or, is the starter working properly and the engine won't run and ends up draining the battery?
If it is a crank no start condition, take a look through this link and see if anything helps:
If it is something different, let me know. Also, feel free to ask questions you may have.
Aug 21, 2020 at 1:46 PM
VANDERBIE
The battery is fine. It's just thrust a lot while driving and when stop it idles high and low. I had to hit the gas a lot while starting the car. So could it the fuel pump or battery. It will shut off and i can get a jump and it will start. I did a fuel pressure tester it was reading at 45psi is that low on the vehicle listed above.
Aug 24, 2020 at 10:11 PM
Based on which engine you have, it could be low. Here are the specifications based on the vehicle's VIN number (serial number). These pressure indicate an engine code by a letter (U, T, V, or Z). If you look at the VIN number on the vehicle, the 8th digit from the left is the engine code. Check that and compare it to this info
2002 Cadillac Truck Escalade V8-5.3L VIN T
Fuel Pump Pressure
Vehicle Power-train Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Specifications Pressure, Vacuum and Temperature Fuel Pump Pressure
FUEL PUMP PRESSURE
Measure with the Key On Engine Off with the fuel pump commanded ON.
Vin (V,T,U)
Fuel Pressure (gasoline) .................... 55-62 psi
Vin (Z)
Fuel Pressure (ethanol) .................... 48-54 psi
________________________________
Based on your description with the idle, it could be something as simple as a vacuum leak or idle air control valve (IAC). The IAC is responsible for maintaining the engine's idle speed. A vacuum leak can also affect the idle and vehicle drivability.
Here is a link that explains how to check for a vacuum leak. Check this.
Also, let me know if the check engine light is on when the engine runs and if you had the computer scanned.
Take care and let me know if you have other questions.
Aug 25, 2020 at 7:57 PM
