Car idles at high rpm?
2006 CHRYSLER PACIFICA
175,000 MILES • V6 • 4WD • AUTOMATIC
BEETLEPUNK21
  • 124 POSTS
I started my vehicle up the other day and the RPMs shot up to about 3000 and then would fluctuate erratically. I have attached the codes that I pulled. I need to note that there is a pretty decent sized hole in the muffler. Would that have anything to do With the issue?
Jan 15, 2026 at 2:39 PM
The hole in the muffler should not matter. To me it sounds like the throttle body needs to be serviced which is what I would do first, here is a video to show you how on a similar engine.
https://www.youtube.com/watch?v=Ui8zhMLp5EM
Please go over this guide as well.
https://www.2carpros.com/articles/engine-idles-too-high
If you have a vacuum leak or the MAP sensor is dirty this will cause a lean condition which can cause high idle as well. I would remove it and clean it, here is the location. Check out the images (below). Let us know what you find, clear the codes once the repairs have been made.
Jan 17, 2026 at 9:49 AM
BEETLEPUNK21
  • 124 POSTS
It was the map sensor. Thank you so much for helping!
Jan 18, 2026 at 12:49 PM
Good to hear, please use 2CarPros anytime we are here to help. Can you please leave us a rating?
https://g.page/r/CZdEnyCkGgm6EB0/review
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you !
Jan 19, 2026 at 6:56 AM
BEETLEPUNK21
  • 124 POSTS
Of course! I actually rated you a couple years ago on google, but i just updated it to a more lengthy review with excellent Service.
I tried posting on sitejabber, multiple times, but it wouldn’t let me finish. Just kept buffering and not finishing for some reason.
Thanks again!
Jan 20, 2026 at 7:15 AM
Way cool, thank you so much! Use 2CarPros anytime, we are here to help.
Jan 20, 2026 at 9:16 AM
