Car idles at over 4,000 rpm's
2004 SUZUKI FORENZA
54,854 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
D2004.FORENZA.
  • 4 POSTS
The problem that i have with the car. At start up it rev up to 4000+ rpm's. I change TPS and the IACV and still does the same thing. Prior to TPS and IACV, head gaskets were done. Any good advice on here would sure be appreciated.
Aug 28, 2019 at 2:47 PM
Welcome to 2CarPros.
Does the idle return to normal? If it doesn't, have you checked the throttle cable and linkage for something causing it to stick?
Take a look through this link to see if anything is helpful.
https://www.2carpros.com/articles/engine-idles-too-high
Aug 28, 2019 at 6:29 PM
D2004.FORENZA.
  • 4 POSTS
The idle does not return back to normal. Checked the linkage and throttle cable and they both look good. I will look through the link and see if anything helps...
Aug 28, 2019 at 10:42 PM
D2004.FORENZA.
  • 4 POSTS
I appreciate the help Joe.
Welcome back:
Do me a favor. Disconnect the throttle body cable from the throttle body and see if that changes things.
Let me know, and you are very welcome.
Aug 29, 2019 at 6:13 PM
D2004.FORENZA.
  • 4 POSTS
Hey Joe so here is what is going on: The piston rod snap and broke from the last start. I pick up another motor from a junk yard. No timing belt on. So I tried aligning the crank and both cams. So I did and it starts and then shuts off. Any idea? Sound like it's choking.
Sep 23, 2019 at 8:45 PM
Welcome back:
It could be anything. Have you checked for engine vacuum leaks? Have you checked for trouble codes?
Sep 24, 2019 at 4:55 PM
