This sounds like a clock spring to me. I attached some detail about this to try and explain it a little better.
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
More than likely when you turn it is making contact and the horn contacts are stuck so when they make contact it sends the signal to the horn. I included the process on how to replace it if you agree that this is your issue.
Let me know if you have questions and we can go from there. Thanks
Oct 8, 2019 at 5:25 PM
