Car hesitates when accelerating
2004 PONTIAC GTO
138,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
SEBASTIANTUDON
  • 30 POSTS
Car hesitates at low speeds, if I’m driving at low speeds and do a mild acceleration car hesitates and then picks up speed it takes a few seconds and kinda jerks forward.
Feb 5, 2020 at 3:43 PM
Good evening,
Two things come to mind.
https://www.2carpros.com/articles/engine-hesitates
1. Low fuel pressure. Test the fuel pressure to be sure it is correct. Low fuel pressure will cause this issue.
2. A partially clogged catalytic converter could cause this as well as the engine cannot breathe correctly.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Feb 5, 2020 at 6:39 PM
SEBASTIANTUDON
  • 30 POSTS
If it is something with the fuel system does that mean the fuel pump is going bad?
Feb 5, 2020 at 6:47 PM
It is possible, yes, but needs to be confirmed.
It could also be the regulator or injectors as well.
Feb 5, 2020 at 6:54 PM
SEBASTIANTUDON
  • 30 POSTS
Is there a way to check the regulator or the injectors?
Feb 5, 2020 at 7:46 PM
If you test the fuel pressure, that will tell you if you have the correct pressure, then you can also see if the pressure bleeds off. It will lower a little but should no go to 0.
I posted the procedure in my first response.
Feb 5, 2020 at 7:57 PM
SEBASTIANTUDON
  • 30 POSTS
Thanks for the info, appreciate the help!
Feb 5, 2020 at 8:01 PM
No problem.
You are welcome.
Always glad to help.
Feb 5, 2020 at 8:02 PM
