Wow, that cold already? We need to get this working. I have a question. Do you mean the blower motor (fan) only works from time to time or is the vehicle only producing heat from time to time?
If it is the blower motor, there are a few things that can cause it. For example, the blower motor itself may be failing. Also, there is a blower motor resistor that may be faulty, but that should still allow the unit to work at high speed.
The one thing that I feel (in theory) that may be an issue is the blower motor relay. The relay itself can be failing.
I attached a pic below showing the relay location and what it looks like. See if you can locate it under the dash near the blower motor. You can test it or try replacing it. It shouldn't be expensive. If you want to test it, here is a link that explains how it's done:
Also, do me a big favor. Check the connector at the blower motor and resister for any indication of overheating.
Let me know if this helps or if you have other questions. Also, pic 2 shows all three things to inspect. The FET functions as the resister and is responsible for fan speed.
joe
see pics below.
Oct 29, 2023 at 8:41 PM
