Car has no power in drive
2007 DODGE CALIBER
58,000 MILES • 2.0L • 4 CYL • 2WD
NICK HORNER
I know the car is a CVT transmission you just did not have that in your selection. But what happens is when i put my car into drive, there is zero power going to it, it will only hit 2k rpm, and even in neutral and drive, i couldnt even push my car home, it was like all 4 breaks are locked. But when i put it into reverse, it drives fine, no clunking or anything that seems like the brakes are holding.
Jan 6, 2016 at 3:58 PM
JOHNNYT73
  • 924 POSTS
I would believe you may be having transmission failure. I don't believe it is a brake issue since when you put it into reverse that it drives fine. If it were the brakes it would be all the time. This is something that needs a pro to take a look at.
Jan 6, 2016 at 5:37 PM
NICK HORNER
its not the transmission, i just got it up to 100 km today, with no gear changes, or drops. also theres a little plastic piece at the bottom where the transmission is, i can see the belt and everything still spinning fine.
Jan 6, 2016 at 5:43 PM
NICK HORNER
also i get zero error codes. and the tranmission isnt overheating. thats why i dont believe its the trans
Jan 6, 2016 at 5:44 PM
