engine low power - limp mode?
2016 HYUNDAI SANTA FE
72,437 MILES • 4 CYL • 4WD
JAVONNE HARRISON
when i go up a hill sometimes the car seems to shifts gears. after that when i press the accelerator it acts likes it doesn’t want to go especially when i stop at a red light, it acts like it doesn’t want to accelerate. when i put the in park and stop the car and let it rest a little bit, i start the car up again. it’s drivable again. it doesn’t happens sometimes. i took it to hyundai dealership and they said they couldn’t find the issue? what should i do please and thank you.
May 9, 2021 at 8:28 PM
Has the check engine light ever turned on while the engine was running? Are there ever any odd smells or smoke when it happens?
May 10, 2021 at 8:16 PM
This sounds like the car is going into limp mode. To be sure lets run the codes. here are guides to help us fix it:
and
https://www.2carpros.com/articles/reduced-power-limp-mode
May 11, 2021 at 12:14 PM
JAVONNE HARRISON
no my check engine light isn't on or no smoke.
May 26, 2021 at 9:18 PM
When this happens, is there anything noticeable that is out of the ordinary? For example, a rattling sound under the vehicle? An odd smell from the exhaust?
I have seen the insides of the catalytic converter come loose and block the exhaust on and off. It's a thought. Without diagnostic trouble codes, we have to inspect one circuit at a time (or at least consider one at a time).
Take a look through this link and let me know if anything seems to mirror what you experience.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
May 29, 2021 at 6:53 PM
