I want to know if my car will be expensive to fix. The problem it failed on is, exhaust carbon monoxide content after 2nd idle.
Jul 1, 2022 at 4:13 AM
CERTIFIED EXPERT
This could mean the trole bore is dirty and needs service. Here is a guide to help you clean the throttle bore, also the engine needs to be tuned up if it has not been done recently. Once other thing is a vacuum leak which the test should be done when the engine is cold. Here are three guides to help us fix the problem:
