Car failed MOT?
2009 PEUGEOT 107
131,200 MILES • 1.0L • 3 CYL • 2WD • MANUAL
STUART HALL
I want to know if my car will be expensive to fix. The problem it failed on is, exhaust carbon monoxide content after 2nd idle.
Jul 1, 2022 at 4:13 AM
This could mean the trole bore is dirty and needs service. Here is a guide to help you clean the throttle bore, also the engine needs to be tuned up if it has not been done recently. Once other thing is a vacuum leak which the test should be done when the engine is cold. Here are three guides to help us fix the problem:
and
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
and
Jul 1, 2022 at 6:41 PM
