I have a 2008 Chevrolet Cobalt with about 75k miles. It has mostly expressway miles and I noticed recently it pulls to the left slightly and I notice I have to keep putting pressure on the wheel to keep the car center. It's not horrible but enough to where if I let go of the steering wheel it will start to go to the left slowly but always to the left.
So I went to Sears today and had gotten an alignment here is what the print out stated.
Front:Left
(in degrees unless otherwise specified)
Actual Before Specified Range
-1.2 -1.2 -1.8 to -0.3 Camber
2.6 2.6 2.3 to 3.6 Caster
0.06in -0.11in 0.00 to 0.10in Toe
13.3 13.3 SAI
12.1 12.1 included Angle
Front:Right
-1.1 -1.1 -1.8 to -0.3 Camber
3.4 3.4 2.3 to 3.6 Caster
0.07in -0.24in 0.00 to 0.10in Toe
14.3 14.4 SAI
13.3 13.3 included Angle
Front
-0.1 -0.1 -0.8 to -0.8 Cross Camber
-0.8 -0.8 -0.8 to -0.8 Cross Caster
-1.1 -1.1 Cross SAI
0.13in 0.13in 0.00in to 0.20 Total Toe
Rear:Left
-0.4 -0.4 -1.6 to -0.1 Camber
-0.01in -0.01in -0.01 to 0.14in Toe
Rear:Right
-0.7 -0.7 -1.6 to -0.1 Camber
0.06in 0.06in -0.01 to 0.14in Toe
Rear
0.3 0.3 Cross Camber
0.04in 0.05in -0.03 to 0.28in Total Toe
-0.07 -0.07 -0.30 to 0.30 Thrust Angle
The value under Front, Cross Caster is Actual: -0.08 and Before: -0.8 with a Specified Range of -0.8 to 0.8 Why would this be left at the very minimum and not adjusted? Is this correct? Even the print out has a * next to it which also states: "This value is not within specification. Tire wear, handling and safety problems may result." I called Sears and questions it and the guy said that sometimes it's like that and a lot of cars are like that where the machine doesn't call for an adjustment on that area.. I don't know anything about alignments and don't care to, hence why I paid Sears to do it.
But for those who are experts in this area, would the Cross Caster affect the car and cause it to drift to the left? To me I see -0.8 to 0.8 for the range and at -0.8 it's all the way to the left it can go before going out of range.. which makes me think that could cause my car to drift left.
Also is it normal for the steering wheel to feel a little stiffer after an alignment?
Thanks!
Front:Left
13.3 13.3 SAI
Front:Right
14.3 14.4 SAI
Front
-1.1 -1.1 Cross SAI
Rear:Left
Rear:Right
Rear
Thanks!
Sep 10, 2015 at 8:40 PM
