Hi Joe,
Yep. That is the latch. Those have a gear inside of them and when the latch hits the striker on the door post the gear spins and then locks the latch in place over the striker which holds the door closed. When that gear wears out, you only get the first part to hold which causes the door to stay open just a touch. Then you can push on it and it will latch. Eventually, your door will not latch at all.
Here is the procedure for replacing that latch (assuming it is the front door because it did not say if this was a coupe or sedan).
Please let me know if you need anything else.
Thanks
Kenny
Oct 21, 2020 at 5:50 PM
(Merged)
