Engine does not crank
2005 ACURA RL
115,300 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
DIGITALSONATA
After a recent inspection of my car by a local garage, my vehicle now on times will not crank even if all the lights come on the dashboard.
I have got it tested at Advanced Auto Parts and they found the battery, starter and alternator perfectly fine.
I have followed your writing on resetting the security system by disconnecting the negative cable on the battery. So far it has been working okay (but it is only a day since) but don't know for how long.
I don't know what the mechanic inspecting my car did to it. Any advise?
Thanks.
Feb 15, 2021 at 4:21 PM
That is an interesting one. If everything is checking good, let's see if it continues. It may have simply needed reset. However, if that changes, there could be a weak connection to the battery, the starter could be going bad, there could be a relay issue and so on.
If the problem happens again, let me know. I will walk you through the things to check to determine where the problem is coming from. Please keep in mind, I am assuming you mean the starter wouldn't engage even though other electrical components are working.
I'm going to add a link that explains how to test a starter. I'm adding this in the event it happens again. You can follow the link and let me know what was found.
https://www.2carpros.com/articles/starter-not-working-repair
Let me know if things change or if you have other questions.
Take care and God Bless,
Feb 15, 2021 at 4:55 PM
