Have you checked for engine vacuum leaks as well as the idle air control valve (IAC)? The IAC is what maintains engine idle speed.
Here is a link that explains the most common cause of a stall at idle condition. Take a look through it and see if anything helps.
https://www.2carpros.com/articles/stall-at-idle
Here are directions to service the IAT:
https://www.2carpros.com/articles/idle-air-control-valve-service
Here are directions on how to find an engine vacuum leak:
Start with checking those things first. I have the specifics on the IAC. It is located on the throttle body. I attached a pic below showing what it looks like. The pintel, which I circled, is what allows a specific amount of air to enter the TB when the throttle plate is closed (idle). If it is plugged and air can't get in, it will stall the engine.
Let me know what code was originally found and what you find.
Oct 20, 2020 at 3:52 PM
