If the battery keeps failing, it is one of three problems. First, as you already mentioned, the battery is faulty. If you question this, charge the battery and have a parts store load test it for you. Most do it at no charge. If it does fail the test, it should be replaced for free if it is only 4 months old.
Next, if the battery is failing overnight when the vehicle isn't used, then we have a parasitic draw. In other words, something constantly is draining power even when everything is turned off. Here is a link that will help with that concern.
https://www.2carpros.com/articles/car-battery-dead-overnight
If the battery fails while you are driving, then the alternator is the most likely cause. Again, you can have a parts store test the alternator free of charge. Or you can check the alternator at home to determine if it is charging. All you need is a multimeter or voltmeter.
Here is a link that explains how it's done:
I know this may be confusing. Please let me know if you have questions and what I can do to help.
Dec 11, 2022 at 7:41 PM
