Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Lincoln
Mark VI
Engine
Symptoms
Stall While Driving
Will not stay running
1982 LINCOLN MARK VI
75,000 MILES • 5.0L • V8 • AUTOMATIC
ENRICQUE725
MEMBER
1 POST
FOLLOW
The car has a little trouble starting and will only keep running if the gas pedal is pressed in otherwise it shuts off.
May 22, 2021 at 10:17 AM
CERTIFIED EXPERT
This is common when you have a vacuum leak or the throttle bore needs to be serviced. here are three guides to go over when fixing the problem:
and
https://www.2carpros.com/articles/stall-at-idle
and
May 23, 2021 at 10:22 AM
